How did you fix? Replace the PCV? If so, which one did you use?
Removed it all together. Temporarily "jimmy-rigged" a filter via a hose to the pcv (it is still in the engine) and plugged the hole on the vacuum block for the pcv. So no more boost going through the pcv.
we all go through it. tend to overthink these cars at times. I'm one that's guilty of that at times, especially the whole pcv thing. I've just finally come to the realization all my smoke is coming from the heads. Either the valve seals or the guides themselves. Just gotta remember these are 25 yr old cars and small things tend to wear over years, even pcv valves. Just think how many times that original pcv check valve has bounced back and forth and how much wear it has!
Granted the amount of times the pcv has to move to do its job, but I just got it replaced when the car as at Jim Dunn's place with a genuine ac delco. I checked my other pcv valves and the same thing, they leak.
The fumes though, are burning my eyes after long rides. Going to have to install a catch can though. Honestly, I can't smell a thing, so I'm confused as to why my eyes were burning after about 15 minutes of driving, windows 1/3 open.
