I'm installing ZQ8 springs from an S10 4.3. they drop the S10 1.5", so I think it should drop my car 1.5-2" what do yall think?
I have an aluminum headed/intake 350, so weight should be close to the 4.3
I need to select my shocks for this setup. what is a good set of shocks that will work with a 2" drop? will s10 lowering shocks work?
Next question.
I'm using Energy suspension poly bushings up front, I will use the provided grease as much as I can, but if I run out, can I use petroleum jelly to grease the bolts, rather than the silicon stuff?
I guess I have to grease between the urethane bushing and outer/inner shell, despite the fact that they SHOULD never move independently of one another? I thought the only movement was the inner sleeve against the mounting bolt (cross shaft on upper A-arms) and of course where the urethan rubs against the frame.
Next question.
