Robert Walton
Proud to be an Infidel
- Jun 1, 2004
Has anyone found a "bolt" on hub for the LS1 conversion??? Instead of machining the original rotor to size. Gracias
Mad_Trbo said:Don't most people doing this swap go ahead and change put the upper control arm as well as the spindle from a donor junk yard car?
Robert Walton said:Has anyone found a "bolt" on hub for the LS1 conversion??? Instead of machining the original rotor to size.
Mad_Trbo said:I see, what does one gain between the two. LS1 is larger rotor?, by how much?
Robert Walton said:I've been told by some machine shops that cutting down the stock rotor for use as a hub could be dangerous. The heat from machining takes the temper out of the rotor/hub. Also been told that most replacement rotors are made of inferior off shore metal and could be brittle to start with.
84TXGN said:Aftermarket LS1 rotors are said to be inferior. All the LS1 guys I know stick with stock GM rotors and have not had a problem. I'm sure a good baer or wilwood rotor would not have the same defects as the autozone special rotors though.
IF you have done this conversion, where did you get the caliper adaptor made?
hybrid85 said:check thses hubs out, i saw them on ebay.
http://cgi.ebay.com/ebaymotors/ws/e...2602&ssPageName=MERC_VIC_ReBay_Pr4_PcY_BIN_IT
bruce said:But those are for the tall spindles.
DavzGN said:Try these then
http://cgi.ebay.com/ebaymotors/C5-B...ryZ33564QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
David
87GN
Check their other auctions the have brakes for c5 brakes calipers too.
