LS1 MAF conversion 3.5"
turbojitsu85
OK I know it's in the wrong place but here me out it's more of a hotair question.Where did everyone get the piping and or connections for the airfilter to LS1 MAF? My air intake isn't stock anymore it's a homemade coldair kit for the most part but this new 3.5" MAF is bigger than the current pipes by just a little bit and the rubber connections. Where is a good place to look for bigger pipes and the connections? I'm more conserned with the conections because the current ones won't work the inside diameter is to small. The pipes inside diameter is about the right sizeas the MAF but not the outside diameter of the pipes.
Mark Huffeman can most likely help you out. He's the one that does the cold air kits. Also Al the tinman can most likely help you with a nice piece that will fit.
