I have a '93 Z28 with a 396in LT1 and a FAST B2B setup. The heads are off the car right now so I can find TDC pretty easily. I want to take this opportunity to mark the harmonic balancer and get my crank reference angle and timing dead on.
How are you LT1 guys doing this? What's the easiest way to find the exact horizontal center of the harmonic balancer and what are you marking the balancer with? Are you painting a stripe on it, grinding a line it? Also, what are you using for a timing pointer? If anyone has any pics of their setup or can describe exactly what I need to do to get this thing right, I'd really appreciate it.
Also, what's the best way to find TDC? I can rotate the crank and visually see when the piston 'appears' to be at TDC but I'm afraid that's not very accurate. Is there some type of tool/guage I should use to find TDC?
Thanks.
Thanks.
