Lubed speedo cable now pump runs constantly
87geeinn
Buick and AMG pilot
Julio,
Took the dash apart to lube my speedo cable and now, key on, the pump runs wide open. I checked the "Power Injection" bulb to see if maybe it got pinched and was grounding out but it looks fine. What else would cause this?
Edit: While I was in there, I disconnected the connector that feeds the factory tach because I wanted to leave it unhooked and not distract me while driving. Plugged it back in and it's fine now. How can I disable the factory tach and not interfere with the alky system's operation?
I was aware of this product but I don't really see how that relates to my question. Maybe I'm missing something here. I've long ago rewired the MAP so that it gets a proper 5v.
Then it's simple
You didn't wire a ground to the map sensor
