Lugnut turns?
CopGn
How many turns do you guys think is adequate for the rear lugs?
Had to go with a 1/4 spacer and was only able to get 4.5 maybe 5 turns on them. Should I get some new rear lugs even though I am not running a slick but a regular radial?:confused:
You should run longer stods. Also keep an eye on the torque spec because the studs are now bearing a lot more weight.
