What’s a creative place for a catch can?
Dhos1
Self-tuning wanna-be
Small ass engine bay that’s overcrowded, what’s creative idea that you guys have done? Pictures please if you can?
Double your pleasure , double your fun!
1 catch can for the PCV system & another for valve cover breathers .
Made a bracket & Mounted on the flat spot on passenger inner fender well beside the battery .
I just installed the newest style two stage catch can from Motion Raceworks (link here) behind the driver side headlights. You have to hug the frame rail, close but not touching, but if fits perfectly....the header panel barely pushes on the filter but nothing I'm concerned about. For the vacuum line I bought a 10AN ORB fitting with a 1/8 NPT center hole. From there I drilled and tapped it with a 3/8 NPT tap (you won't tap the entire "length" of the hole) to accept the 3/8 push to connect fitting. I couldn't find this fitting ready to buy, but maybe I didn't look in the right places. With this setup I'm able to remove the filter through the oval hole behind the catch can and install / remove the 10AN crankcase line. It's also easy to drain under the front bumper.
I ran the 10AN line along the driver side fender and then through the oval hole to the catch can...I checked and there is plenty of clearance for the hood to close without any interference. (The 3/8 vacuum line is hiding under the 10AN line...both fit)
I am working on a new setup for my GN. Will post some pics later of the mockup. Got one of Moroso's larger style oil/air separators, not vented. Has a billet mounting bracket that I made an adapter to bolt up to a t bolt clamp with a bracket. T bolt clamp goes around the AC accumulator. Now I am doing this while the motor is out so hoping that I will have enough clearance to the downpipe for the drain off of it.1745773176532.png1745772531870.png
Yes but try to find a 3.5" one. I also bent the t bar a bit to get it to fit better. Like I said I am still experimenting and if I ever get my motor installed will post more. I am hoping it is going to fit! Have one of Whoosh motorsports PCV and a Racetronix check valve plus fittings, hoses ready to go.
Here’s the link to how I did mine. One for PCV and a smaller one for the valve cover breathers.
Update 6 months later! Finally got my new build in and running. Oil catch can is mounted to ac accumulator. Did notice my BLMs at idle are now 142 and after about 200 miles I had about 3 teaspoons of oil in the catch can. Not sure how good that Whoosh PCV is but did notice it is no longer on their site. Have a feeling it is working too good. Going to try restricting the flow is see what happens. Do NOT have any exhaust leaks pre turbo or vacuum leaks. Motor runs strong, vacuum at idle is 18-19. Here is a pic of the install. Won best motor at a show yesterday. Ran with no PCV for about 10 years but got tired of the fumes. W
Update 6 months later! Finally got my new build in and running. Oil catch can is mounted to ac accumulator. Did notice my BLMs at idle are now 142 and after about 200 miles I had about 3 teaspoons of oil in the catch can. Not sure how good that Whoosh PCV is but did notice it is no longer on their site. Have a feeling it is working too good. Going to try restricting the flow is see what happens. Do NOT have any exhaust leaks pre turbo or vacuum leaks. Motor runs strong, vacuum at idle is 18-19. Here is a pic of the install. Won best motor at a show yesterday. Ran with no PCV for about 10 years but got tired of the fumes. WView attachment 408097
Here’s the plastic PCV valve that I’ve been running for years without issue when I had some high BLM issues .
This was recommended by Eric Marshal of TurboTweak.
I’m running dual AMW catch cans mounted on the flat section of passenger side wheel well (directly behind the battery)
One for the PCV system & the other catch can for the valve covers
It’s been many years since I found these . It was one of the Big Box Auto Parts Stores . Sorry, but I don’t recall the name though . Picked em up in the Philadelphia area.
Do a search under the part number 1162 , think these were listed under different manufacturer other then Deutsch
Here’s an old thread I just found
Looks like it was AutoZone
Check under Luberfiner 1162 PCV valve
Here’s another thread link.
Looks like the part number may have been changed up too? 🤷‍♂️
So came up with this restrictor with different size inserts. Used -6 to -6 oring adapters on each end. Used the smallest one and did see the numbers drop on the BLMs to 128-130 at idle in gear. Didn't run a pcv for about 10 years but the fumes were starting to get to me. Friends following me to car shows didn't like it either.
[td]Adjustable PCV Restrictor Valve, -6AN
Part #: FO-06R
Got from improvedracing.com Was $20 plus shipping
