SignUp Now!MIB said:I trying to find someone who can help me figure out how to tune it better. The car has gone 10.41@136 on pump gas, 19PSI and ET Radials. Car is very rich but it still makes good power. Any help would be greatly appreciated. Thanks
MIB said:I have a couple of guys with fast systems local but this is a different animal. The principle is the same but there are some functions that I am not familar with. Car has a Duttweiler built 274, GN1's, 76, etc. Car 60fts in the 1.4's on ET radials rich. I took a look at the WB so I know it's not tuned correctly. I am just suprised that this car made it on the 2004 Hotrod Power Tour running on this current tune. I appreciate your help and if I can't get it closer on my tune I may have to drive it down to Charlotte. I may just end of up taking over to Reds over EVTB to verify what I am reading. I appreciate your suggestions and help. Thanks
MIB said:6000 .80/11.8, 5000 .85/12.5, 4000 .85/11.8, 3000 .85/11.5, idle .85/11.5. Car idles fine, it does not stumble. I am running NGK TR6's and I am checking plugs often. Car will run rich initially after startup. Once operating temp is reached it clears up, somewhat. It's when a transition from idle to light/heavy throttle that I see/smell gas. Main fuel tables for idle are:
Eff\RPM 1000 1500
175 31.5 32
160 31.5 33
145 32 33
130 31.5 31.5
115 31 31
Ignition tables are:
Eff\RPM 1000 1500
175 26 26
160 27 27
145 27 27
130 26.5 28
115 29.0 30.5
Overall trim 12.5%
Lamba Tables: range from .85-.97 depending on load. The RPM's are the same 1000-1500. I normally see .88 to .94 @idle.
