Maf Pro and Alky! Where to get chip?
RUQWKNF27
I plan on changing over to the Maf Pro set up and running alky too. So I know turbotweak makes the best chips for alky. But is there someone tha makes chips for alky and for the maf pro to work .
If you plan on running speed density, I think you will need to run Full Throttle's chip.
To take full advantage of the Maf Pro system get your chip from Mike at full throttle as well. With his chip it will allow you to use the Maf Pro to its fullest abillity. I also had a TT chip on my car prior to going to the Pro set up and loved it, but switched to the Pro Chip as well after talking to Mike on the phone.
What did you have to change on the maf pro to run the alky if you used the chip that mike provides for it? Or does Bob make a chip to run alky with the maf pro.. I guess the answer to my ?'s lies in "what makes a alky chip a alky chip".
Generally it's the WOT timing and the amount of WOT fuel that is removed. Just get the Pro chip and be done with it.
If you run the Maft Pro with a wide band, the wb tracking will automatically decrease fuel when alky is added to maintain the desired a/f ratio.
HTH
David
HTH
David
I would never setup a car like this. I would have it doing zero correction while spraying alcohol.. and if the motor leans out.. let it add.
HTH
Or you could set set it up half way between...... ;)
very tunable no matter how you slice it.
B
