This may be in the wrong forum, but here it goes.
I have a 1996 LeSabre, 3800 Series 2, after the engine is well warmed up, under moderate to hard acceleration the power dies in spurts.
It is like the transmission is slipping, but the RPM does not jump up. I will be accelerating hard and for a split second the RPM will drop and the engine has a corresponding total loss of power. There is no appearance that the engine cuts off - as in the dash board lights do not flash on.
I know the mass air flow sensor is bad, could that be the cause?
