The Translator was not invented to make the turbo Buick perform better. It was invented because the original MAFs that were discontinued were failing and there were no good aftermarket re mans. The 3" and 3.5" MAFs are readily available in the salvage yards as millions of cars were produced with them as standard equipment. The 3.5" becomes necessary when we make more power and are moving more air. The best way to take advantage of the Translators and MAFs is to use them in conjunction with the Extender or Extender Extreme chips as these chips allow the computer to measure actual airflow and adjust according to that information. The Extender chips and the 2nd gen Translators,when used in conjunction with each other, make for a highly adjustable engine fuel and spark managing system. If your original MAF is good,you're good to go.
