BoostKillsStres
TIRE-FRYER VIA HAIR-DRYER
 - May 25, 2001
Goal:
Get the BL table values that are at extreme ranges closer to 128.
Question:
If I have good idle bl #'s based on the injector constant but have other cells which are on the extreme high and low end, what is the correct method of maf table modifications for correcting this?
I have and understand the full maf table frequency vs. gps info and also the BL table boundries info for RPM vs. gps and am thinking the following:
Hypothesis:
If the BL # is low you need to find the gps range when you are in this cell and in learn mode then lower the maf table number for this frequency so less calculated fuel will be delivered thus the BL's should raise and be closer to 128.
If the BL # is high then conversly find that gps range when learning and raise the maf tables in that range so the calculated fuel increases for that range and the BL's should lower and closer to 128.
Questions / Comments:
Is this hypothesis correct? Am I going about this in the right fashion to get BL's which I have in the low 100's closer to 128 and my cell 15 which is in a 153-156 range closer to 128? By the way I do have a cell 15 lock patch in place but would like cell 15 closer to 128 so when chip swaps are done the car doesn't feel lean until in gets learned into the 150's.
TIA
Question:
Hypothesis:
TIA
