Pronto
No amount of evidence will ever persuade an idiot.
- Dec 9, 2002
Turn the 6* advanced back to 0 and see what happens.
SignUp Now!what do you thank on the settings in the picture I sent youThe car runs great but I want to be safe on my settings. Thanks
I have a scanmaster but where does it show knockI would turn the extra advance back to 0 and the WOT retard back to 0. I don't know what the Extender chip is normally burned to but most street chips pull some timing at WOT in third and forth gear so the extra retard is probably not needed. You have higher octane gas in and it's still pinging (not good) with that much advance. Adjust the box then start it and drive it lightly and see how it feels. Do you have a Scanmaster? If so and you see knock get out of it right away.
The right side has dashes so I hope that's good. I guess went I say knock its more of a pinging sound. I know they are the same.When the car is turned on and the Scanmaster starts up the numbers on the left is the O2 millivolts. On the right side of the screen is the knock retard. Your goal is no knock retard. Knock retard is the ecm's attempt to save your engine from destroying itself from detenation that it hears by way of the knock sensor on the back of the block.
Learn about the Scanmaster here:
http://www.vortexbuicks-etc.com/Scantool_Readings.htm
Also in other parts of the website is lots of info on tuning, racing etc.
I use the maft pro with the extender chip. I use it in translator mode. I also have closed loop boost control. I would be hard pressed to trade the set up. Using in translator mode requires no normal driving tuning, and I can easily make WOT fueling and timing adjustments. With the wideband I also have closed loop WOT A/F control. You have to do a little bit of studying to get it set up and use it, but very powerful tuning tool.
switches and 4 dials. I put a new extender chip in yesterday. That is programmed for 93 octane and without Alky. The car started great and drove good but if I get on it hard it will ping. I am not sure what I should set the dials to with this chip. Also I have an adjustable boost rod. Should u adjust that to slip on or pull it some to get it on which I know will increase boost. Thanks in advance.
Bob I have the translator plus which is around a 2001 year wiswhat chip number, is your timing harness connected, what are the dials set to in the translator, how much boost are you running?
Bob
Bob
not set the right way. I went from a chip that was set up for Alky and 98 octane to no Alky and 93 octane.
