So now I have to find Federal Mogul 107M 0.001 oversize bearings . Anyone got a good source . I've not had much luck looking on the net
Or - I have contacted Federal Mogul and asked if the #3 and #4 journal bearing top halves can be mixed and matched which would also solve my problem since there is that much difference in the bearing thicknesses .
The bearing top/bottom for 3 and 4 do have different #'s [ ie 1116 and 1118 respectively ] but maybe it makes no difference if a # 1116 and 1118 go together
Go ahead and mix and match shells halves to get the clearance you need. Install the thick half in the block side. How ever carefully check rotating torque to make sure you aren't touching a bearing shell.
