Main bearing part # please.
Mike T
Would anyone happen to have a part # for a main bearing set with a .010 oversized thrust flange (.010 thicker) and a .010 under journal (to fit a crank turned .010) ?
I found this one (MS1747P10) in clevite that definitely has the .010 over flange but it's not clear what the journal size is.
The end play is at .012 and I'm trying to get it a little closer to spec without turning the thrust surface.
Yea that sucks, I would call bearing manufacturer and get info strait from horses mouth so crank wont have to be welded and machined back down. your not too far over but definatly needs correcting.
