turbo96max
- Jun 6, 2007
Need some help. I was driving the car and it totally died on me. After towing it to a local shop ( bad move). The guy found that the main relay was rusted to hell, so that must be the issue he says. I didnt want to leave the car there so I asked him if there was another relay he could make work. He said no but i can get it going for you. He jumped the relay using direct wire connections. The car started but the alarm was still activated bc it turned off the minute i stepped on the brakes. After that it never turned on again. After replacing with the new relay , still wont start. There is one light pink ire with a black line, that goes into the relay that still doesnt have power. When I add power to it, the car will start ( i hear all the electrical parts come to life) any ideas where there might be an additional fuse. I followed that wire the best i could but it seems to be going to the canisted under the driver headlight, but that has never been connected before and the car would start just fine??????????The only thing that has power is the headlights and interior lights, no radio, no ignition, wont pop the trunk, alarm wont work , nothing.
also may just happend to go bad at the same time. The ac relay on the right fender is acting up after that, when ido add power to that wire that is dead on the main relay, and start the car, the ac relay doesnt turn on the compressor, when i wiggle it around , it starts working. coinsidance?????
