Had oil pan off for rear main seal decided to roll in a new set of rod and main bearings. bearings were a little worn not bad some stuff embeded in them from what our wonderful filtration systems let through. until i got to the main thrust bearing the thrust side of bearing towards rear of engine was worn considerably and has grooves in it the crank was also worn a little and starting to groove. however the thrust side of bearing facing front of engine not hardly worn at all.. anyone else run into this? have included pics engine is bone stock first time oil pan has ever been removed 41k miles 86 gn
what can cause this?? somthing in trans/convertor forcing crank forward or misaligned pulleys pulling crank forward?
had another 86 gn with 60k miles i put bearings in it to and don't remember the thrust bearing being worn like that
the crank does have end play in it now without the engine running there is nothing forcing crank forward i will bring my dial indicator home from work and get the exact end play reading with new bearings tonight
top pic thrust toward front of engine
second pic worn side of thrust bearing towards rear
i know pics arent that great time to invest in better camera
