V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
Ive been using 1157s and they are fine, even though the car calls for 2057's. Now, from what you described, (lights dimming on and off etc) Id say a bad ground. Also, the flasher on the fuse box is your hazard flasher, the flasher to the right of the steering column underneath is the turn signal flasher. This sounds like a frustrating problem. Good luck! By the way, you dont have any LED bulbs in there do ya? I found that you can put 1157LED bulbs in the back but not the front. kinda wierd but true, in fact when you put 1157 led's in the front, the two turn light indicators come on when you have your lights on. Real wierd. Well hope I helped. If not, GO TO HELL!!!!!!!!!!!! lol j/k
Scott
Scott
