Well i had nothing to do and since the trans shop would not look at my car today and made me bring it home because it was running bad for the test drive.
I pulled the pan again, i found that i had the old o ring to the filter [i think] was in the pan. well i checked the gov out and looks great. So like a dumb a-- i droped the valve body witch was not bad but i riped the gasket that is right on top of the valve body and under the metal shim or plate. where can i get this gasket and can i.
2nd - my tv linkage in the trans, it only pushs the tv rod in about a 1/4" at wot is this to little and could be why it wopuld not shift to sec.
looks like its time for a good trans cooler with a fan , i also found a little water in the trans[ rad lines leaking] very little.
