I had to remove my turbo from the pass. manifold and now it leaks. I pulled the nuts off, removed the oil line and pulled it up as far as I could, about 1/4" and there is no seal or gasket. I know this is supposed to be flush without a gasket but I don't think I can pull it all apart enough to file it all flat. Someone mentioned a copper gasket. Will this work well and if so, where can I get one? Any other ideas? What about pulling the drain tube? Do I need to worry about leaks when I put it back on, if I remove it? I am short on time but I want to do it right this time and I also want it to look good. TIA
