Jackie grabos
- Feb 2, 2011
hey, im about to get a manual boost gauge. i belive it is similar to rjc gauge. i would like my car to be set to 15lbs of boost, maybeup to 18lbs when i get knock gauge. my first question is does it matter where i place it? do i need to place it before the y in the tube that goes to actuator from solenoid or do i place it after y in hose to actuator? the latter placing it closer to actuator after the y in hose. next was wondering how many times to screw in controller to set to 15lbs? and finally, how long or short should i set the actuator arm? i guess how many threads from being screwed all the way to the left where screw is closer to wastegate, the higest setting. thanks
