Sack's I got my pedal out today and your calculations are spot on. I ended up drilling my hole 2 1/4 below center point of upper pivot pin. This will give me a 6:1 ratio. I have Aeromotive brakes on all wheels. They recommend a 7:1 ratio, but that is with the 1 1/8 bore diameter master cylinder they sell. My master cylinder came TRZ but the instrutions in MC package were from Strange Engineering. The instuctions with the master cylinder said for a 1.125 bore master cylinder ratio should be 6.5:1 and the 1.032 bore diameter master cylinder (like I have) ratio should be 5.5:1 ratio. So I just went between to 6:1 ratio. I just welded up orignal hole and redrilled because they were close together.
Powermaster pedal length from center pivot hole (top) to center pedal pad= 13.5 inches
Powermaster pedal length from center pivot hole (top) to center push rod hole (after removing)= 2.75
thus 13.5 divided by 2.75= 4.91:1 ratio
for mine 13.5 divided by 2.25= 6:1 ratio
yours 13.5 divided by 2.125= 6.35 ratio
Michael
Michael
