Ive switched to manual brakes on my 85 and the pedal is way to mushy.Ive read about putting in residual pressure valves(I have a 5# for the front and 10# for the rear)I read where everyone says to replace the stock prop valve located down on the frame....
Which prop valve do I use and where do I buy it from?
Will the 5# residual valve be ok for the front?
I will also be installing adj prop valves on BOTH the front and rear brake just to have the adjustment there in case I need it...Thanks for any input!!
