manual fuel pump in a turbo block
1dollardog
Are we there yet?
Is it possible to put a stock n/a fuel pump in a stock turbo block? Does the turbo cam have the lobe to operate the pump? I have a 84 gn short block and may use it in an old jeep without an electric pump. Also I have a msd dual points distributor for it. I know this is a pretty elementary question but after I have the #1 piston tdc on compression stroke which way should the body of the distributor (or the vacuum advance) be facing when I set it down in? In other words someone talk me through timing this thing:)
