Manual lock up switch how to?
I believe it is as simple as running a two wire switch. Ground one wire and run the second to the top left terminal in the ALDL connector. I believe gnttype is down right now so I can't go double check but I believe it's the top left hole.
The switch will ground the TCC circuit regardless of ECM request. To install, run a wire from a ground location to one end of the switch and run another wire from the other end of the switch to terminal F on the ALDL connector under the radio pod. (As you are looking at the ALDL connector, terminal F is at the top left.) The easiest way to do the connection is to splice into the wire behind the connector.
