Map Kpa To Map Psi
89TURBOTA
can you guys give me a listing of the kpa map # converted to psi
up to the 3 bar
thanks
robert
ok here goes
if around 100 kpa is 0 vacumn and boost ,
then anything under 100 is vacumn , but if you convert it to psi it says 14.5 psi, which i think is 14.5 which is equal to atmopsheric pressure
so if 158 kpa=22.916 psi then in order to get the correct psi above atmospheric pressure you have to subtract 14.5 from 22.916 which gives you 15.4 psi
so 158kpa is 15.4 psi in the f.a.s.t. tables
am i right ? let me know guys
thanks
I think you can also use 0.145 as a multiplier. But you're right above.
100KPa X .145=14.5psi
Re: ok here goes
if around 100 kpa is 0 vacumn and boost, then anything under 100 is vacumn
Yes that is correct, 100 kPa is approximately atmospheric pressure, less than that is a vacuum, more than that is positive "boost" pressure.
Atmospheric pressure at sea level is 14.7 psia. 14.7 psia is the same as 101.325 kPa 14.5 psia is the same as 100 kPa.
Close but not quite.
158 kPa x 14.7/101.325 (or 158 x 0.145 as fast4d pointed out) = 22.9 psia as you figured out above.
Then 22.9 - 14.7 = 8.2 psig "boost" pressure. Not sure how you got 15.4, finger probably slipped on the calculator or something :)
John
thanks john
yeah it was a slip of the fingers , i see now how it works
i wish they would have just put psi instead of kpa , it would have been easier, but i guess it was a programming issue
thanks guys
robert
thanks guys
robert
I might have missed something, are you talking about a Accel
DFI or a Speed Pro system? Or neither?
The Speed Pro system can change the dash board to read PSI.
My old DFI system would not and I agree was a pain.
Take Care
Neal
