WH1_T-Type
- Jun 1, 2009
So I've got a Devils Own progressive kit and a 3bar map that I am installing. I've read a few schools of thought on the map
1) REPLACE the stock MAP on the passenger inner fender with it and then tap the controller into the green stock MAP wire under the dash
2) run that same stock MAP line to the 3bar map (leaving the stock in place) and then to the controller.
Any thoughts?
Any thoughts?
