Eric Phillips
- Feb 1, 2013
I have an 86 gn that I am trying to figure out the hose routing on the tag shows some but not all i need to know where the hose from the map sensor should run to and also mine is digital dash which has the factory boost gauge. so trying to figure out where the hose off of the boost transducer on the inner right fender next to the map sensor should go pictures or info would be greatly appreciated. thanks eric
