MAP sensor location?
Depends, do you have an analog or digital dash? If Digital, yes, you only have a MAF, & a couple hobbs switches for the High/Low boost. If you have an analog dash, you have a MAP, only for the LED boost "gauge". If you have a MAP its on the passenger fender, should have a vacuum hose leading to it.
Yep, the MAP is only for the LEDs. If you get an alky kit, then the MAP becomes more useful:D
That's it on the right (or bottom). Passenger fender.
