Mark VIII fans
PaulBZ65
likes g-bodies
Fan #1- 3 wire connector, white plug. Works good, no defects! Tested with video if interested. $60
Fan #2- 2 wire connector, white plug. Works good! Does have a chip in one blade, but works/sounds fine. Video of this one too. Plug connector is short but enough wiring to use. $40 due to the chipped blade.
Buyer pays shipping costs, should be about $20 in the US.
Hello Paul,
Would you mind measuring the outside dimensions, less the brackets? And the thickness? If not, no problem.
Thanks for any help,
Paul Lohr
Sure thing, less brackets the fans shroud is 22" wide and 19" high, I have it at 5.5" deep from the center of the motor. PM reply on it's way...
