- May 25, 2001
Does anyone know if this can take timing out or just add to the timing?
SignUp Now!Originally posted by dennisL
I'll take this one Carl so you can rest tonight.
Yes, you can add or subtract advance by using the MAT table. The code only adds the MAT table value to other values it has for spark advance calculation. However, there is a bias value for the MAT table ($160) that gets subtracted. So, if the table # is greater than the bias #, the advance is added. If the table # is less than bias, the advance is subtracted.
("advance is subtracted" - sounds retarded)![]()
Example: $160 = 20 (hex)
- if table value = 23, 1 degree is added
- if table value = 20, nothing is added
- if table value = 1D, 1 degree is subtracted
Originally posted by bruce
Not to be attempted without acult supervision,
My thought is to use the MAT Timing table for somthing a bit different.
It looks to not be used in a stock prom.
If i'm right thinking the way the MAT works, if you have a resistor there you can basically tell the ecm that its xx temp and it will add or subtract timing according to the table.
What i'm looking to see if its possible is to say have a some sort of setup where you can set the resistance to a value (one on either end of the scale) on say a switch and tell it to pull some timing while thats on... sort or a retard switch.
I had real good luck with my friends car pulling about 4-6deg of timing out when spooling up at the line.
Or to take this further (I don't know a whole lot about electronics) but how about somthing to vary resistance (a pot of some type) to take out or add a bit of timing (not a whole lot, don't want to go to 27deg of timing w/o adujusting fuel delevery)
basically tune the timing with a nob![]()
Originally posted by BoostKillsStres
aaahhaaa!!! I always knew bruce was into the acultHow else could he spew so much TR tuning knowledge
ATR made a box that changed timing and plugged into the MAT some years ago. It does work. However, like Bruce said, you'll probably want to zero out the MAF vs airtemp correction table. So there is a trade-off (unless you have a new style maf that does its own correction).
Just remember that changing the MAT changes the fuel calculation!!!!! ! !!!! ! ! ! !!!!
If you want an in cab way to change timing get the Translator Plus.
The reistance vs degree mat is not linear, if you want to build an ecm bench to see what you really have, OK, just installing a variable resistor and willy nilly changing the timing IS NOT the way to go.
Please, study the fuel correction before getting in there with your dial a timing stuff. You'll see how the fueling changes.
Does the Translator/LS1 maf do the temp corrections already?
What happens when someone uses the boost sensing harness with turbo link?
Its using the MAT input connected to a MAP sensor.
Does that affect fueling?
I'm going to have to get chip burning stuff again so I can play with this stuff..... sorta wish I never sold it....
If you're running a translator then you can mount the MAT sensor in the plenum and get accurate about your timing corrections.
TType85 - just to give you a feel for how the MAT sensor works, I looked up some resistance values from the service manual. The first thing to note is, as the temperature goes down, the resistance goes up.
Here are some sample numbers:
275 degF - 100 ohms
100 degF - 1.6 K ohms
70 degF - 3.4 K ohms
20 degF - 13.5 K ohms
-40 degF - 100.7 K ohms
The stock MAT table is setup for the range of -13 degF to "hot as hell". You can change the minimum temp if it makes it easier (smaller range of resistance values needed). But like Bruce said, it's not linear so think about a multi-position switch with fixed resistance at each position.
Originally posted by Donald McMullin
Bruce: Found your pictures of the relocated MAF and liquid cooling which shows your MAT in the side of the TB plenum.
Great work on the liquid (fuel) cooling.
Good enough for now.
