stack1
Senior Stacker
- Oct 7, 2006
How much boost can I squeeze out of a stock turbo with an adjustable actuator, 55#'ers and running on alky?
SignUp Now!I'm wanting to get out of the PT54 since I overlooked the torque converter. I had the TT chip made for the PT54 for 22-24 boost. Am I going to have to send the chip back just for the turbo change? My block is unopened and heads untouched.
You can make your actuator adjustable or buy one. If you install an alky kit you will want to always run it. It only comes on with boost and it's progressive so more boost=more spray.
Exactly what he said....
Once you run it with..... you will never want to be without....
Well what I want to do won't necessarily work out with what's going to happen. I'm gonna be moving so I'll be driving my car across the country in January and I don't think I'd be carrying too much alky with me for refills. I'd go through a lot of methanol with my lead foot driving 4000 miles.
Ed Brewers 11.3 run on a stock turbo was at 28 PSI 1st gear and 28 degree's timing.
So dont limit your thinking
So much for the 21-22 lbs of boost quotes I hear all the time in regards to the stock turbo being done after said boost levels :biggrin:
I hope to push that envelope as well as soon I get the new TT E-85 chip
