If you unhook the ecm wire (small orange wire/blck connector) at the battery, this will put the chip back to default settings.
If the ME16 you have is for the combo you have, this should be fairly close (Steve Y is very good at what he does)
Do that and drive it....see where you are at....
You DONot really want to go to zero...that would be way to lean.
Youo know where you're at by looking at your scan tool. Where it displays it settings is different on different scan tools...I can't even remember where it displays on mine....but it displays. As you switch through the settings, it will change the number showing what # you're at. It will also change as you adjust the chip.
The ME is a very simple setup to use BUT it is very confusing at first...initially overwhelming...after you "get it" you'll love the chip....you really need to read EVERYTHING EVERYWhere you can....The lightbulb will come on
Here's the ME message boardand site address:
http://maxeffort.tripod.com/
http://members.boardhost.com/MaxEffort/
Read read read....
If you DON"T have a scan tool, leave the chip in it's defaults until you do (disconnect the ecm power wire)
If you don't have directions, leave it in default as well...
