Max Effort Chip
87turbot
16 Position Dual Timming Mer Maffles Chip W Thump Wheel 240.00 All Complete W Instruction Its Set Up For 55 Lbs You Can Get It Recalibrated For 20.00
So this is the mafless set up. You have the map sensor and other stuff. I have the max effort with maf system looking to switch.
If your looking to switch you will need to send your computer out to get modded via Steve.
Its The Maffles One Does Not Need A Mass Air Flow Sensor Or Oxygen Sensor It Com W A Set Of Map Sensor Harness
