Guys-
If you use the Mcmaster nozzles in your DIY setups and want to duplicate the SMC nozzle elbow-
You will need a 1/8"-"street elbow" and an 1/8" coupler. BUT- you need to drill out the inside of the male end of the elbow after you put on the coupler! If you don't you will destroy the rear of the nozzle when you try to tighten it, as there is not enough clearance inside the elbow for it to fit.
