I'm running the stock DP/wastegate setup on my GN. I've got a 3" Mease DP on order. My question is: when you convert from the stock DP to the 3" DP without the elbow, do you have to re-adjust your boost level on the wastegate rod or does it retain its old setting? Don't want any big surprises when I take it for the first test run.
I know it's a small point, but I'd like to know what to expect when I finally get to bolt the new DP on the GN. TIA!
Steve
Steve
