Mease Stock Location IC
HALF DUZZIN
Up for sale is my used Mease Stock location IC. I had this unit PSI tested and all 4 areas were repaired professionally. This unit has been 6.70 on a not so aggressive tune up.
My Set-Up:
Stock bore w/55lbs injectors. Ported Cast Heads and Intake, 70 mm Turbo, 3.42 gears, 3800 stall.
How many rows and how much $$$?
I believe it's like a 13 row....Don't quite me, I will find out for sure. I don't know what it's worth. A local guy has offered me $350, but he hasnt come thru.
Just count the rows. Looks like 24 rows to me.
You just count them, they are right there
Thank you for the full view photos.
As mentioned, it is a 24 row unit. Just count the horizontal tubes, there are 24 rows of tubes with cooling fins in between them, not including the top and bottom plates.
Thank you for the extra info. That is a very good price, you should be able to sell that easy. Shipping maybe stiff though.
If you have the scoop and brackets I will take it for $350 If the shipping isn't sky high.
Thanks for your interest. I have one bracket without a shroud. I know it sounds crazy, but I hadn't run a shroud in a few years and this IC still performed. The only reason I'm getting rid of it is because my new setup requires me to have a front mount (mo' power baby) I will look for the other brackets today. Im a newbie, so if say something that doesn't make sense let me know.
