Mechanized
Hi
I just finifshed putting in the mech oil gauge. I tapped off of the oil sender unit (I'd rather not tap the turbo feed line). I used a Home Depot 1" nipple (this is all threads) then to an all female "T" and then to a "street" elbow (one side is female and one is male). I put the original sender in the elbow and the oil gauge stuff in the "T". It is a litte tight that is why I have the sender on the outside. I ran the nylon crap up and to the right (towards the driver side, along the fuel return) and along the top of the wiring harness to the firewall. Don't go nuts tightening the ferrule things becasue you can cut the nylon tubing. Autozone sells a coper tubing kit for $13.00 or so.
I bought the console gauge mount from John's performance. Although the website says it is $24.95, the invoice says $31.50. I emailed him about it and he has not responded.
Oh, I also bought a cap in case I spring a leak, I can cap it (the oil pressure gauge) off.
Bill
