melted coil while key on engine off position.
checked them. all good. and i have power at the pink wire going to ignition module
No fire meaning the engine doesn't fire off or no fire meaning you have no spark?
some of the aftermarket replacement modules are much less tolerant of the CAM sensor timing. I would re-time the cam sensor by hand and try again.
turbobob, why would it get that hot with the key on engine off?
it shouldn't, I think your original module failed, and melted itself down.
Did you open the coil pack/module? The epoxy inside may have melted with heat causing a short
