Metco lower control arm brackets
Major Nutz
These have been on the shelf for a while so I thought I'd see if anyone needs them. It has all the hardware that came with from metco. I can text pics to anybody interested. $50 plus shipping.
Thanks,
Mike
Straight from their site:
Instant Center Modification Brackets
1978-1988 GM G-Body (Monte Carlo, Malibu, Regal, Cutlass, Grand Prix)
The Metco relocation brackets are manufactured from heavy-duty laser-cut steel, precision-welded on a fixture, and powdercoated for long-lasting surface protection. The kit includes brackets for the left and right lower control arms, Grade 8 hardware, and detailed installation instructions.
The installation of these brackets lowers the rear mounting point of the rear lower control arms, modifying the vehicle’s ‘instant center’. The ‘instant center’ of the vehicle is the point at which imaginary lines drawn to extend the vehicle’s upper and lower control arms would meet. The brackets cause this imaginary point to move toward the rear of the vehicle, reducing the tendency of the rear of the vehicle to ‘squat’ during hard acceleration. Power normally absorbed in suspension compression is instead applied to the suspension mounting points, driving the rear tires downward and significantly improving traction. The principle is the same as the one behind the 'lift bars' that were popular years ago.
These brackets are recommended for vehicles used primarily in drag race applications, and are generally not recommended for vehicles used exclusively in street applications or vehicles used for autocrossing or road racing. As anti-squat is increased, anti-dive characteristics will increase and some vehicles may experience instability during hard, high-speed braking. The installation of the ICM brackets is a complex operation and should not be attempted by an inexperienced installer. The bracket positioning requires careful measuring, including pinion angle determination, to assure proper installation.
Note: Metco ICM brackets are compatible with Metco lower control arms only. The control arms are sold separately.
