Sep 9, 2009 #1 0 03FatBoy Member Joined Nov 10, 2008 Messages 594 I have been searching the forums, but to no avail. I have couple questions... 1. Where to buy Methanol in the northern Virginia Area? 2. Storage concerns... how long does it last, plastic vs. metal containers? Thanks!
Sep 10, 2009 #2 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 03FatBoy said: I have been searching the forums, but to no avail. I have couple questions... 1. Where to buy Methanol in the northern Virginia Area? 2. Storage concerns... how long does it last, plastic vs. metal containers? Thanks! Click to expand... Look here.. if this doesnt lead you.. dont know unless you have some local guys in your area running methanol. http://www.turbobuick.com/forums/alcohol-nitrous-propane-tech/121500-methanol-sources.html Container.. plastic and keep the cap tight, and tank off the ground. The pails are coated for storing methanol, if you buy your methanol in a coated metal drum.. then its no problem.
