Meziere H2O pump
vacuum 6
I see many threads but not a lot of info.
Looking for feedback on this pump.
I'm running a CAS V2 FMIC, aluminum 2 row single pass rad, stock fan, stock water pump with straight water.
AZ is balls hot. Car runs 190-200° all the time
Before you try a new water pump, replace the stock fan with a dual fan setup. That should help a lot especially with front mount inter coolers.
There are many members here including myself run the Chrysler Intrepid dual fans from early 90’s. They require simple mods to mount them and electrical harness adapter and relay. Do a search and you’ll find plenty of info.
I'm running dual Spal fans and a big aluminum radiator with a front mount in Phoenix. 180 to 210 degree running temps aren't unusual to see.
If you want to pursue a Meziere pump, I have one for sale.
Interesting.
I've had her since 2010, this is the second engine. It's always run that way. Runs nice and cool on the coast by Lou and Mike...
New engine has TA Aluminium Heads, too. Old one was Champion Irons, if that matters.
Thanks for the info. Seems to me the spal brush fans arent getting it done. I'll review some BLDC fans, design something up and post back.
