84' TurboRegal
Only a 6 cylinder?
- May 31, 2010
What would be a good mild build for the 84 engine, The boost gauge only reads about 5#'s of boost and the trans wont go into overdrive until about 70mph... I'm planning on pulling the engine out over the winter and doing something to it, but i don't exactly know what. I want to go with the TA-33 turbo and 60# injectors, i know i need a fuel pump and the hotwire kit. What would be a good cam, and should i change from the stock pistons to something a little more agressive, also can the heads be milled, ported and polished, w/o risking anything else?
