I have a slight miss in my 84 t-type.I replaced two of the spark plug wires on the passenger side after developing the mis-fire. One was burnt from the up pipe flange. I re-routed the wires so that they wouldn't come in contact with the up pipe flange. I tested the third one on that side that I replaced about a month ago, and it tested really good with an ohm meter. I am using MSD superconductor wires. They have super low resistance. I had driven it two days , back and forth to work until I got a chance to replace the wires. The wires on the driver's side are older, but they have a tendence to last better because there is less heat on that side. I also tested all the coils on the 84 coil pack. I got 12.4 on two of the pairs, and 13 on the last pair. Anyways, I still have the mis-fire, although not to the same degree as before. I really notice it when I bring the car above five lbs of boost or when the alcohol spray turns on. I'm wondering, could I have fouled the plugs when I had the bad plug wire? Should I suspect the coil that reads 13 ohms? Or should I focus my attention on the older, drivers side plug wires, even though they look ok from a visual inspection? The plug wires are the easiest thing to check. I have no way to test the coil under load, only while the car is off. What type of plugs are recommended? I currently run NGK u-groove copper plugs. I'm just trying to avoid having to replace everything.
