TurboWh1
- Aug 12, 2002
A. turbo 86-87 crankshaft-$100.00
B. front timing cover with oil cooler housing-$85.00
C. stock throttle body and upper plenum-$75.00
D. 6 stock rods with 30 over pistons (unsure what brand) $85.00
E. 6 stock rods with TRW 30 over pistons and ARP bolts-$175.00
F. aluminum accessory bracket-$75.00
G. power steering pump with pulley and metal feed line-$65.00
H. stock balancer-$60.00
I. crank pulley and balancer extension-$50.00
J. a/c compressor condition unknown-$40.00
K. throttle body hard vac lines-$40.00
L. waterpump pulley-$25.00
M. oil tube and dipstick-$45.00
N. 6 Blue top 36lb injectors-$85.00
O. GN fuel tank and sender-$100.00
P. SG1 30 over block with caps, cylinders #3 and #4 have chips out of the bottom. Engine ran fine with pulled. It looks like a factory defect. I heard GM had casting issues. $250.00
All prices plus shipping.
