F
Fred 86 GN
Guest
As I go through my transmission rebuild, I am coming across various stuff that is confusing or questionable that I would like some other opinions on please ![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
1) the ATSG (?) manual I bought for the 200R4 shows and calls out for two (2) wave washers in the forward clutch pack. The Helm manual only calls for one. My trans builder only remembers using one in the past. We assembled it with one and it seems OK...but for the record which is correct?
2) Is 0.060" for the direct drum and 0.040" for the forward drum clutch pack clearance appropriate? Do you guys "cram" the feeler gages between the upper ring and the retaining ring, or just go for a slight "drag"?
3) The direct drum backing plate was warped (looks like a big bellville washer!
) and I got a new one. What could have caused it to bend out like that?
4) Will a .005" high by .010" wide ridge around the outside diameter on the direct drum cause more than a small matching groove to be worn in the band?
5) After seating the direct and forward drum assembly into the transmission housing, we measured the distance from the drum to the big counterbore in the casing and it was 4.4-4.5". Both the Helm and the ATSG manuals say it should be 4.125". Where could we have lost 3/8"??? We installed a .100 thrust washer under the assembly.
6) Which do you guys prefer -- steel check balls or the viton rubber check balls for the valve body?
7) How do you route the transmission pressure gage into the car to monitor it while driving?
Thanks for your input!![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
![Eek! :eek: :eek:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
