Misc. Turbo Regal Stuff (TA49, TA54, Ign Module, Coil Packs, MAFs, Horn Ring, Clear Lenses...)
do you still have the egr stuff with lines? wish i would have noticed mine were mia before you shipped out the tire stuff. hows 20 bucks plus 5 for shipping? thought about a block off, but i have the valve,, just need the solenoid with hoses.
Just what you see in the pic. It's yours if you want it.
The following items are all sold:
Scanmaster
Vacuum lines
Tire hold down stuff
Chips
Casper’s Extend Ground Kit
Casper’s Tach Module
Casper's Tach Mating Plug
MAF Pipe
Boost Controller (Black)
Boost Controller (Brass)
Clear Lenses
EGR Stuff
Front License Plate Bracket
Fuel Pump Hotwire - do they both used the same size feed wire back to the pump? Also how long is the wire to the fuse block from the ring terminal?
Interested in one of them, most likely the older one.
I'll measure it and let you know.
