Miscelaneous Gn parts 4/sale
49-blues
I have 2- ratiator supports, 2-stock driveshafts, 2- good condition grey pullstraps, 6-stock unabused piston rods, 3- front stock caps, new unused alky system with injection through plenum plate, 4-sets of chips extreme extenders- 65 lb chip, 75 lb chip, 2- 83 lb chips, brand new set of 75 lb injectors and 1- slightly used set of 83 lb injectors, 1-trans crossmember bar, 4- American racing outlawII 8.5" x 15" with 3.75" backspacing, 1- new set never driven on Centerline autodrag 5.5" x 15" front wheels, 1- new pair of Mickey Thompson sportsman pro rear tires 26" x 12.5" fits without notching, and 1- brand new set of BFG drag radials, 275 x 60 15, 1- turbo support bracket and 1- alternator bracket- all parts are negotiable, partial or full trades accepted-make offers-let me know what you need-Matt
It's an older kit, I think I bought it from BGC but never installed, it has a plate that mounts under the plenum with a perferated copper tube where the alky is sprayed, it comes the plate , pump, ss lines, a couple different jets that fit inside the ss braided lines, a aluminum stogage tank& all neccessary minting brackets-I ll get some pics of everything this coming weekend.
brand new set of BFG drag radials, 275 x 60 15 how much?
new unused alky system with injection through plenum plate is this for a stock set up or will it work on a bowling green?
thanx mike
Looking to get $300. For the drag radials-I could meet you in jersey for the exchange, the alky kit is for the stock style plenum-that's the reason I'm selling it cause I'm running a bgc intake which the plenum is alittle longer.
hey 49 blues i might b a bit confused on the part is the radiator support the big piece that bolts up to the inner fender walls and bolts down to the frame forks?
