My three GNs are long gone and I'm finally getting around to selling my inventory of parts that I accumulated. All parts are new unless stated otherwise. Many of these are no longer available so here's your chance to stock up as I once did.
Pg and item number refer to the 1982-1990 44-W Illustration Catalog.
Prices are per piece unless stated otherwise. The number after the price is the quantity available.
Prices do not include shipping and insurance. PM me with your wants and your zip code for a shipping and insurance quote.
I prefer PayPal. Check my eBay feedback (sumnerw) - it is 100%.
All transactions will be on a first paid basis.
Keep an eye out for more listings - I still have a lot of stuff to dig out!
GASKET, OIL PAN (One-piece rubber) (pg 0-43; item 43) GM #25521994 $16.00 1
Camshaft position sensor shim/tension washer kit (0.031") GM #1837617 $1.00 5
Timing Cover Gasket Set Fel-Pro TCS45930 $7.00 1
HARNESS, INJECTOR WRG - Used GM #12046082 $30.00 2
GASKET, INT MANI PLENUM (pg 0-47; item 18) GM #24502089 (replaces 25525140) $4.00 1
GASKET, INT MANI PLENUM - Accufab Accufab $4.00 1
COVER, EGR VALVE (pg 0-47; item 20) GM #17069228 $10.00 1
CONTROL, EGR VALVE VAC (pg 0-47; item 23) AC Delco 214-307 (replaces GM #25527186) $65.00 1
CONTROL, EGR VALVE VAC - Used, with mounting bracket GM #25527186 $30.00 1
FILTER, EGR VALVE VAC GM #10159525 $4.00 1
SENSOR, ESC KNOCK (pg 0-47; item 25) AC Delco 213-325 (replaces GM #1997562; 10456287) $40.00 1
GASKET KIT, INT MANIF (pg 0-47; item 37) Fel-Pro MS96033PB $20.00 1
RETAINER, ROCKER ARM (plastic plug that holds rockers in place on shaft) GM #1254371 $1.00 20
Turbo Inlet Gasket (triangular - from 1984 Riviera) GM #1261269 $5.00 1
Head, Bolt - torque to yield (long - inner row center; 2 per head) (pg 0-47; item 66) GM #25525953 $3.00 9
Head Bolt Set (4 long, 12 short) Fel-Pro ES74022 $18.00 1 set
HOSE, WATER BY PASS (pg 0-47; item 71) GM #25525245 $22.00 1
HOSE, WATER BY PASS - Used w/ clamps GM #25525245 $10.00 1
SWITCH, CLNT TEMP (pg 0-47; item 75) AC Delco D1896 (replaces GM #2506371) $9.00 1
SWITCH, CLNT TEMP - Used GM #25036371 $4.00 1
GROMMET. RH VLV CVR (pg 0-47; item 80) GM #1264486 $2.00 1
GROMMET, INT MANIF C/CASE VENT VLV (pg 0-47; item 82) GM #1381487 $3.00 1
VALVE, C/CASE VENT (pg 0-47; item 83) AC Delco CV893C (replaces GM #2509468) $4.00 6
HOSE, WASTEGATE (pg 0-47; item 86) GM #25525576 $21.00 1
VALVE, SOL WASTEGATE - Used (pg 0-47; item 87) GM #1997157 $15.00 1
SWITCH, FAN TEMP (pg 0-47; item 91) AC Delco D1874D (replaces GM #3053190) $20.00 1
GASKET, TURBO OIL DRN CONN (pg 0-47; item 97) GM #25537227 (replaces 1256780) $2.00 6
HOSE, HTR OTLT (pg 0-47; item 101) GM #25525228 $10.00 1
SWITCH KIT, OIL PRESS (pg 0-47; item 109) AC Delco D1816 (replaces GM #25036378) $6.00 1
PCV Hose (replacement for discontinued original; cut to size) GM #10055808 $9.00 1
GASKET, HARN VAC (pg 0-47; item 122) GM #25523194 $1.00 2
PLATE, RAD GRL NA "BUICK" (1987) (pg 1-10; item 11) GM #25526879 $20.00 1
CORE, FUEL FEED PIPE VLV (pg 3-30; item 7) GM #25532663 $2.00 1
GASKET, THROT BODY (pg 3-38; item 1) AC Delco 40-752 (replaces GM #25517008) $1.00 10
GASKET, THROTTLE BODY - 70 mm Accufab $4.00 1
Idle Air Control Housing with 4 mounting screws - Used $5.00 1
MOTOR, IDLE AIR CONT (1986-87) (pg 3-38; item 2) AC Delco 217-.437 (replaces GM #25527077) $50.00 1
GASKET, IDLE AIR MOTOR (pg 3-38; item 4) GM #25530697 $1.00 2
SENSOR, THROT POS (1986-87) (pg 3-38; item 5) AC Delco 213-918 (replaces GM #25036663) $40.00 1
PEDAL, ACCEL CONT (pg 3-78; item 5) GM #1256427 $7.00 1
SENSOR, M.A.P. (3 BAR) AC Delco 213-101 (replaces GM #12223861; 16040749) $60.00 1
HANDLE ASSEMBLY, CONT LVR, COMPLETE (MED DK GRAY) - Used (pg 4-107; item 23) $10.00 1
SWITCH, PRESSURE (INC. O-RING #18038508) (pg 4-129; item 1) GM #18018141 $80.00 1
GASKET, DIFF CARR CVR (8.5") (pg 5-13; item 33) Detroit Gasket 3605 $2.00 1
BALL JOINT KIT,UPPER CONT ARM (dust boot is torn) (pg 6-25; item 8) Moog K5208 $20.00 1
IDLER ARM Moog K6187 $25.00 1
HOSE, P.S. GEAR INL (PUMP TO STRG GEAR) (Reproduction) (pg 6-69; item 2) Kirban 6943 $30.00 1
VALVE, HTR WAT FLOW CONT (pg 8-74; item 1) AC Delco 15-5320 (replaces GM #25523118) $34.00 1
HOSE, HTR INLET (pg 8-74; item 2) GM #25525213 $10.00 2
HOSE, HTR OTLT (1.097) (pg 8-74; item 6) AC Delco 14174S (replaces GM #25525228) $11.00 1
CLAMP, S/S ROD (for sunshade) GM #20294600 $2.50 2
CLIP, W/STR SI RL RET (Window Blow Out Clips)(pg 12-242; item 56) GM #20153291 $2.50 1
BUMPER, Trunk Lid (3/4" across flats, 11/16" diam., 1-1/4" long) GM #12337963 $2.00 2
Valve Stem Caps - Gray $2.50 12
Retainer Clip - ECM Cover Panel - Gray $2.50 2
Retainer Clip - ECM Cover Panel - Gray - Paint flaking off; need repainting $1.00 2
Fuel Line Tap Caspers 102071 $15.00 1
Front Turn Signal Lens Covers - Tinted (1 pair) Lund 37081; 37082 $30.00 1 pr
Stock Downpipe Gasket ATR $5.00 1
Exhaust Header Gasket Set Fel-Pro 1400 $20.00 1
GM Style Black Hyper Flex PullThru Bump Stop for Control Arm (1 pair) Energy Suspension 3.9102G $5.00 1 pr
Tie Rod Adjusting Sleeves (black) w/ stop nuts (not black) (1 pair) similar to Hotchkis 1601 $40.00 1 pr
